Stock Spring Pads
Old Nov 21, 2002 | 11:54 AM
eee's Avatar
eee
Question Stock Spring Pads
I had my springs changed a while back and I like the look in the rear. The front, however, seems higher than the rear. At the time I had my springs changed I had no idea the spring pads even existed. I have a clk 320 coupe. Does anyone know what the stock pad size is in the front, what size should I go to...to even out the front and rear, and would it be very difficult for me to perform the installation myself?
Old Nov 24, 2002 | 06:18 PM
theine's Avatar
2014 GLK250 BlueTec & 2009 ML320 BlueTec
The springs I used where HR Sport, with original pads, and the front looks a little lower than the rear, specially from the smaller tires 225 against 255's. I think you will need a spring compresor to change the pads.
Old Nov 24, 2002 | 07:01 PM
eee's Avatar
eee
h&r
I too used H&R springs but the front has a larger wheel gap than the rear. I am using 18"s 255 rear and 225 front.
Old Nov 24, 2002 | 07:33 PM
theine's Avatar
Do you have standard shocks?
Tom
Old Nov 25, 2002 | 09:39 PM
eee's Avatar
eee
yes
Yes, will that make a difference in wheel gap?
Old Nov 25, 2002 | 09:45 PM
LowRydeR's Avatar
I have H&R sport and Koni adjustable, with #1 spring pads all around, sits perfect but I prefer slamming.
-Bruce
Old Nov 26, 2002 | 06:56 AM
theine's Avatar
Talking
I guess you will have to work on the spring pads to bring it at the level you want.
