2000 CLK 430 Convert
1. The first problem is the convert top just top going up and down. This happened completely without warning. I can here something clicking when i press the switch to make it move, but the motor does not engage.
2. I went over some train tracks the other day that I had never been across and the two rear head rests engaged and moved up in a locked position. I resorted to the manual where it says to hold the up button for the head rests for 8 second and then push the down button.....no luck.
3. My factory CD changer no says "no magazine" and then just started happening yesterday.
Since it seems all of this seems to be happening to items in the rear of the car, I am hoping this is just an electrical problem related to a fuse in the rear or something. or maybe nothing is related and I just need to take it in to mercedes.
Does anyone have any ideas for some of the problems I have coming across?
As for your CD player, I've experienced the same issue. I just stop the car, turn off the ignition, remove the key, and start up the car again. It's been working for me.
Good luck with that convertible top issue.
Wow. Did you buy my car or something? I have a 00 Cab. At the time I bought it (2 years ago) i had almost the exact same problems, even the 'no magazine' message on the radio.
You're going to doubt me but here is what fixed the inoperable top (since summer is upon us I bet this is your main concern. *LOL*). The trunk lock. As you may or may not know, there are 3 things that need to work and send correct signal to the central computer for the top to work. They are:
Windows (down)
Headrests (down)
Trunk (locked)
If none of the conditions (in parens) is met, the top won't work.
Does the red light on your console switch flash when you pull it (to drop the top)?
I believe my old trunk lock was sending an incorrect signal ('not locked') to the computer for the top to work because the rear headrests and windows worked fine. My symptoms were similar in that i also heard that clicking noise. I didn't even believe my indy mechanic when he told me what the problem was but when I got it back the next day...voila. And haven't had a problem since.
Here are some questions I have. Does the trunk work with your remote? Is it difficult to open with the key? In my case, the trunk stopped working.
Good luck and feel free to ask if you have further questions.
