Loose Glove Compartment
Hey guys, lately my glove compartment has been a bit wobbly when opening and closing the door. With the door open, you can move it quite a bit. It seems like the whole compartment isn't affixed to the car properly. I figure its a loose screw or something. I've never removed the glove compartment so I don't even know where to start. I haven't had a chance to look further into it. Any thoughts as to what it might be or some quick tips to remove the glove compartment or fix it otherwise. Thanks.
The problem is where the lach on the glove box door meets with the square hook at the other end of the dash and the hook is the problem it is just loose tighten with star head screw driver it happend to me
I just checked it out and the screw on the square hook is really tight. A regular screw driver would not work since it is so cramped in there since the screw is on the "ceiling" of the glove compartment. I took a phillips bit and the screw is as tight as it will go. The whole compartment though slides in and out of the dash about 1/2.
It slides in and out of the dash about 1/2" to an inch.
Originally Posted by ratha67
(Post 2831430)
