Two questions...
CLK 430
Two questions...
One...So I need to change my front brakes and rotors. I'm going to get the R1concept rotors. http://cgi.ebay.com/ebaymotors/MERCE...1942QQtcZphoto Has anyone used them? Also, this may be a stupid question, but do I order 1 pad pin rear caliper or 2 pad pin? I know all I have to do is look, but its easier for me to ask.
Two...After I got my car back from the shop a few weeks ago, my srs light came on. I was at the mechanic last week and they took a look at it and thought it was faulty wire or something, erased the light but then it came right back on, so they think it might be something behind the dash. Anyone have this happen or know what it might be thats causing the light to stay on?
Thanks guys
Thanks guys
2003 CLK500
Sorry, no answers for you, but I would like to know about the SRS Light too. Mine comes on whenever I have a passanger. It goes on and off all the time, unless there is no passanger. Maybe a seatbelt issue?
CLK 430
I heard the seat belt is one of the reasons for the light to come on. There is also a sensor under the passenger seat that could make the light come on for your car. Unfortunately for me niether of those things are what is making the light come on in my car.
2003 CLK500
I'm starting to realize this car has more problems with sensors, than equipment.
CLK 430
Ya I've noticed that too, although I've been lucky, so far the SRS light is the only light that I've had come on. I've only been dealing with body damage. But I hope you get yours figured out and I'll soon get mine figured out-hopefully
2000 clk430
put r1 concepts brake rotors front n back on my range rover.. excellent product u wont be dissapointed. also pads included in my package are virtually dust free and super quiet.. good choice n value equal performance to stock u wont be dissapointed...I get compliments on them all the time..
CLK320, Honda Ruckus, pinto & BMX
my srs, bas, and some other crap comes on..
they only come on once in a while.. i ignore it..
i know that doesn't help you at all, but i thought you should
know whats going on with my car...
put black tape over the indicator, out of sight , out of mind
CLK 430
Scottster77-the black tape idea sounds good until you get in an accident and something doesn't work! Lucky for you the light isn't on all the time.
500E Signal Rot
The BAS/SRS issue is most likely caused by a faulty brake light switch, easy fix and cheap also. Its a common problem.
Little black box under the seat? Hmm, those sound like controllers for the seat motors/heaters. SRS/BAS and seatbelts don't have any controllers under the seats, although there is a wire harness that connects to the passenger side BabySmart sensor and the seat belts.
At least on my 2000 model this is the case.
i recently picked up the R1 concepts PREMIUM double drilled/slotted rotors with pads.
the center of the rotors are casted BLACK.
All i need is the front sensors, before I install....
R1 concepts is in Fullerton California,and their machine shop looks top-notch!
CLK 430
So do you think that maybe my srs light is on because my brakes are really low and the driver side front rotor needs replacing?
