My pad setup good or not?
Old Jun 18, 2008 | 08:55 PM
Focus on this 1's Avatar
Clk 55 04
Hi so I baught the H&R springs (1.4-1.3) for my 320. My stock pad setup is #5 in front and #3 in the back. Im thinking to get #1 front and rear how will the car look too high in the back , just ok or too high in the front
what do you guys think
Old Jun 19, 2008 | 09:25 AM
Williams707's Avatar
2000 CLK 320
Each pad changes 4mm in size so just do the math.
Old Jun 20, 2008 | 07:09 AM
J56BP's Avatar
2002 CLK 430
u can have 5 diff sizes to the front #1(9mm)#2(13mm)#3(17mm)#4(21mm)#5(24mm).....
real 4 diff sizes #1(13mm)#2(17mm)#3(21mm) & #4(24mm).....like $8 ea +tax at MB take my money donation center.
Old Jun 20, 2008 | 08:19 AM
BlackOnBlackCLK's Avatar
2001 clk55 AMG
that's good info to know.
Old Jun 21, 2008 | 11:16 PM
SoCalw11w123's Avatar
if you dont swap out the pads, you might not notice the drop!
I have dove into my suspension 2xs....1st time swapping pads, 2nd time swapping springs and pads again.
im running #1s on front and #2s rear. I still want a bit more....
get #1 pads all around when you install your springs.., you wont regret it.
Old Jun 22, 2008 | 06:53 AM
J56BP's Avatar
2002 CLK 430
but u will end up needing camber (K-mac) kit for real.
i left #3 pads (real) and i need it, negative camber..(eats the inside of the tire big time), only an the right real tho. front is ok with #2 pads.
i quess ea w208 are diff.....
