"NO CD CHANGER" Error & any aftermarket options?
08 CLS63, Honda Accord, 04 911
I know theres a ton of threads out there about CD errors, but everyone seems a bit different..heres what I'm getting:
1. CD Changer plays fine, but gets the above error when either changing CD's or going back and forth to radio back to CD, and so on.
- I pop out the cartridge , put it back in, and it starts to work again.
- eventually it will stop seeing the CD Changer, I've decided not to go back to radio for now.
2. Any use any aftermarket options? like an alpine/kenwood or somthing else?
I read up that if it was the fiber cable then my sound would be cutting out, which its not...any help is appreciated..thanks
CLK but loves my Fords
I had the same problem, I was going to swap the stock unit with a 12 disk alpine, 6 sucks anyways, but now the stock changer works fine again.
Quick update- changers been working for a while..
I noticed when I change CD's from like #2 to #6 or whatever, the playing CD sleeve gets stuck, or the magazine doesnt pull it back in. I can see it still out when I look in the changer.
Eventually causes the NO CD CHANGER error. After a bit it will eject and pull the sleeve back in..
anyone think its just the magazine?
2001 E320 RWD - Brilliant Silver/Ash: 100,000+
You can buy a new magazine even from a dealer for not much money. I have also seen some on eBay. It's probably the least expensive way to troubleshoot your problem so I think it's worth a shot.
This happened on my old 430 on the coldest day of the year in Virginia Beach. I was swtiching through Cd's and then Bam, it would not work.
NO CD CHANGER kept coming up.
I heard you can take it to the dealer and have them relod the software to show it is there or something.....
