O2
Old Jul 19, 2008 | 09:13 PM
Lucas007's Avatar
CLK430
O2
Can I replace my own O2 sensors or should I take it to a professional?
Can anyone recommend, someone in the ATL. Could someone in the area assist me with the replacement.
Old Jul 19, 2008 | 09:32 PM
Musikmann's Avatar
2001 E320 RWD - Brilliant Silver/Ash: 100,000+
Those are normally a 100,000 mile routine replacement part. You can do them yourself and save a ton of money compared to a dealer if you are good with a wrench. If they are definitely needed, I would buy the parts online from autohausaz.com and find an independent shop to do the labor. When one, or more, go bad they trigger a Check Engine Light. Are you sure you need to replace them now?
Old Jul 19, 2008 | 11:33 PM
sfclk's Avatar
1999 CLK320
My bank 2 sensor 2 went off. Which made a code light up for you?
The CEL goes off about every month.
Old Jul 20, 2008 | 09:33 AM
Lucas007's Avatar
CLK430
I have about 130,000 miles. It hestitates/stalls at stops. I replaced the MAF. I was told this would be causing the problem.
