removing the MAF sensor
Hey guys, some of you know that i have been getting a misfire in the cylinder 3 and there was no check engine light so i took the cables out and put them back in nice and tight, so now i have no codes but the car still shakes...i also read on the boards that i might want to clean my MAF sensor with the MAF sensor cleaner...I bought the cleaner from Autozone and in the directions it said i need to open the sensor, now how do i open this thing? Its like rivets in there, do i need a special tool to open it?
Originally Posted by ZEEK
(Post 2947918)
https://mbworld.org/forums/clk-class-w208/189777-instructional-430clk-how-change-air-filter-clean-maf.html Good luck |
I just cleaned my this weekend. Spray it throught the black plastic screen, it is easier. Spray it let it dry and spray it again. Make sure you have cleaner that says "No residue".
Also when you put it back together. Make sure you have a tight seal. If you have a loose seal on the rubber gasket, your care will stall. Once it is cleaned, it will run great. |
thanks guys.
hmm so miniscule but i still havnt done it lol damn lazyness
