Wheel Offset Question
Old Sep 29, 2008 | 08:24 PM
spote3's Avatar
None
Guys, I need some help. I have a set of Maya DSL Wheels from my last car and want to put them on my 2000 208 cab but the offset is wrong. The wheels are 20x9 fronts and 20x10 rears. The fronts are fine, but on the rears the rotor won't reach the wheel center hub because The rear offset (43mm offset) is too high. Is it possible use a 10mm or so spacer to decrease the offset/fill the gap and bolt it up?
Thanks in advance!
Old Sep 29, 2008 | 08:46 PM
sfclk's Avatar
1999 CLK320
i would use washers to measure how thick of a spacer you need. the offset of my rear wheels is ET33 but i don't think it helps much with clearing the brakes/hub because we have different wheels.
