Type of Bulb for center light cluster?
Old Jan 4, 2003 | 09:24 PM
braincuttermd's Avatar
I have the H7 for my low beam and have an extra set of H7s for the inner cluster. I don't want to use them for the high beam and noticed that just below the high beam in the center light cluster is a yellowish driving light. I want to switch that bulb to H7. Is H7 compatible with that center light?
The low beam lights are the PIAA Blue Sparks 7500K and the extra set of H7s are the PIAA Xtreme Whites.
The car is a '01 430.
Thanks.
Mike
Old Jan 9, 2003 | 02:58 AM
CLk BoOst's Avatar
1999 CLk320
the inner cluster has two bulbs... the one that turns on when you turn your headlight dial to the right once ( the one that is always on in the middle when your headlights are one ) is using a .. city light bulb .. there is one more bulb on top of that with is your high beam ( H7 ) bope this helps
Old Jan 12, 2003 | 08:12 PM
What is the city light bulb?
