View Poll Results: how dificult should the fix be?
complicated
33.33%
dont worry youl be ok
66.67%
Voters: 3. You may not vote on this poll
pasenger door has no power!! need help!!
Old Nov 26, 2008 | 12:18 AM
cancun68's Avatar
clk320
I had the Front of the car repainted, and they removed the ir sensor on the passenger door, every thing was working, and when it was all put back in place their was no power to any of the functions on the passenger door,
no window control or seat control not even the light under the door.
the seat does have power, it still moves when you get in the back seat. so i know the trouble is isolated to that door only.
any clues ????
Old Nov 26, 2008 | 06:19 AM
gregory13lil's Avatar
2000 CLK430
This is extremely easy to fix. They just forgot to connect the cables that control the seat inside the door. For some reason if they are no connected the light at the bottom of the door will not work even if they are connected. You can take the door off yourself, BUT...if the car just got repainted I recommend taking the car back and asking them to reconnect the cable again. There should be 3 cables that they reconnect:
1. Puddle light at the bottom of the car.
2. Seat module
3. Main Speaker
This is all they should have taken off of the door to get to the IR sensor, but like I said just take it back and ask them to fix it.
Greg
Old Nov 26, 2008 | 01:32 PM
cancun68's Avatar
clk320
help needed
well according to them, they only removed the IR sensor at the door handle and never removed the door or door panel, now i'm starting to believe that they did remove the door panel...
so if the seat module is not connected
all other electrical functions will not work including the window???
