Cannot turn off ABS BAS ESP warning light off
I dont want to be the one making you buy parts that is not necessary and that may not fix your problem.
you even replaced the disc´s and brake pads bleeded the system and now I dont see any other option left than take it to the dealer, if you want to get rid of the Wanring Light and if it keeps stayin on there might be another important issue..
I remember I had something similar was the hand-brake light on my old BMW E39 after the dealer replaced the shocks when I came to pick it up the brake warning light stayed on after engine was swichted on and it was apparently a loose connection in the dash some where behind the cluster.. they have never touched it but happent anyways and all he did was pull the wires a bit issue solved..
Is what I mean sometimes it can be so simple thing but we get blind and focus the wrong place but you very well and has done all you could...
dont waste any more time and money on this mate take it to the dealer let him find the problem, perhaps they hear about it before and knows excaclty what it is.. Simpley ask them first what it might be post back here what he say and if he starts talking about the stuff you allready replaced just let him know you did and see what he says before you order a time for a full trouble shoot..
Is the best advice I can give at this point all because of what you have done yourself so far and follow other good peoples good advices...
a huge thumbs up to everyone on this thread
From what I know and experience mine can come on and tbe ESP goes off all of a sudden but havent seen it for long time now thank God for that! But what I know is if it stays on all times you should have the car checked properly for worn disc/brakepads be sure these are ok if you know these are ok then stop the car
1 Off the engine
2 pump the brake pedal 3 times you will feel it getting harder as you pump, on the 3 pump keep and hold the brake pedal down while you turn the engine on, when the engine comes on you will feel the pedal fall a bit, it must NOT fall to much then something is wrong but just a bit, with engine on turn your steering all the way to the left / all the way to the right. Check you ESP ABS again...
Hope it helps else I would go to dealer get it checked mate...
it sucks if the ESP doesnt work specially up here where I live right now we got 4 meter snow, ice and - 21 Degrees hehe so the ESP is much velcome :-)
thanks
As i said try mechanic specially since everything else failed..
A faulty switch somehwere can be a cheap repair but also an expensive one... only faith can decide huuh..
No really try the brake light switch and try search forum for that ..
hope it sorts or somebody else reply im dried out for advices
. if anyone else has any advice i would much apreciate it
2)Use brake cleaner to clean rotors and brakes
3)Replace battery
4)Get a new brake light switch
5)Turn stearing wheel All the way to left and then all the way right .About 4x's .
6) check all light Bulbs
7) make sure ESP under the hood is connected .
Look for a silver/metal square that says ESP OR BAS
under the hood and check that conection .
If non of the above helps then TAKE IT TO DEALER
and get it scaned on STAR .
My ESP ABS light is permanently on now .
Before it was just comming on ONLY after 60 plus miles
Per Hour (65mph) on the Highway .
NOW ITS PERMANENTLY ON BUT
IT DRIVES PERFECT .
atleastnow that it is permanently on , its not
Locking my brakes and making the car loose horse power . (I HAVE 19" custom wheels with
235/35/19 in front
255/40/19 in rear
AND I READ THAT THE DIFERENT IN SIZE TIRES
IS MAKING MY SPEED SENSORS GO CRAZY
THERE FOR ABS ESP LIGHTS COMMING ON .
(Changing rear tires tommorow )
To 255/35/19 .
Seems like this causes tears and shorts circuits in the wiring harness, that drop circuit current, but does not blow the fuse. There are discussions on the web about smoke coming out of the steering columns, but mine hasn't reached that point.
I found out several mysterious issues associated with this wiring harness problem including sensor malfunction, airbag popping open, horn going off when you turn the wheel, dash lights dimming, speed sensor malfunction, brake, ABS, ESP, and other weird dash alert problems.
There's a relatively quick work around that can at least temporarily fix it by simply finding the right steering position. The right way to do it though would be to take off the steering wheel, the shroud around the column and taping up the stripped or shorting wires; this would take some work, which most people don't want to mess with.
It's a shame Mercedes doesn't even have a recall for this and the Mercedes stealerships come up with a zillion and one things to change or reset that doesn't fix the problem... they make lots of $$$$$$$$$ out of this changing brakes, sensors, dash cluster, etc. Why fix it?
Every time the telescopic steering is at extreme settings, it shorts out the wiring harness in the steering column. You may notice some of LED dots in the digits of the dash are missing or a quick yellow flash goes off when you pull up or down your steering. You may even hear a pop or loud clunk when you move he steering to the utmost extents inward or outward.
You may have even noticed your problem began shortly after you found the shroud around the steering column started wobbling possibly due to pushing the telescopic steering all the way toward the dash.
The work around is to not push the steering column to extreme extents, either too high up or too far down... or too far from the dash or too close to it.
I found the best position for my steering is about around 1/2 inch before it gets to the very highest vertical position and around 3/4 of the way telescoped out. You'll need to try different positions, but start from there.
By the way try turning the shroud left and right and up and down as you telescope the steering away from the dash... it may snap in place and stop wobbling. I'm really disappointed in Mercedes Benz as they did not correct this problem for 11 years! Good luck and hope this stops your frustration.
these models only got telescopi sterring wheel in and out. Not up and down..
Wish you good luck but for me is family time today...
Next week lowering my MB just got my H&R springs yaaaahoo
Good luck with it..
I just wonder why it happens when I never have touched the telescopic?
Tink I done that 1 time, but was to take out the instrument cluster...
Anyways cya later..
Did you buy the car new or perhaps someone before you or a lame MB service tech or indy had the the thing apart and didn't put it back together correctly? Don't know that I would point a finger at the oldest car maker in the world for a bad wiring issue.
- left-right-left wheel lock
- adjusting the seat and steering wheel depth and height
- reset the settings on the dashboard
- turning the EPS button on and off
- turning the EPS off, resetting the settings and turning EPS back on while driving (it worked at the time but then reappeared after turning the car off and then back on)
I then decided to wash the car because I noticed a lot of brake dust on my rims (I recently replaced by brake pads). I also took the car out for a 30 minute drive. After driving for 30 minutes, I turned the car off and then back on. The error message had disappeared.
I was curiouss , so I took the car to MB dealer, for some reasons they call me the next day AFTER i dropped the car the day before early in the morning . They told me that the ESP CONTROL MODULE read failure , the part by itself is $1400 and to be installed $476 more, so I declined the work and fiugred out first what should be the right issue.
Right know my car drives fine, I haven't gotten the lights on again, BTW when these light comes up, the car drives rough, specially the steering wheel.
I had a shorted seatbelt harness one time and experienced these woes.
Disconnect battery, follow through with ESP, SRS, BAS reset procedures which include engine running doors closed, brake applied. turn the steering wheel from stop to stop. lights will disappear.
If the fault returns while driving then there is an issue to be dealt with by a MB technician. can be steering sensor or wheel sensor, few other problems but the majority of problems stay inherent.
I get a different fuel trim when the CEL is on, Plenty of power but poor quality. possible ECU file to go closer to limp mode when the car gets a hiccup. The SRS modules on my W124 are like new but there is no network to fail on that model as well.
A search in the C63 forum might yield stronger results.
Cheers, Gator
Anyone have any other idea of what the problem could be? What else can I do myself, besides take it to the dealership or a mechanic to have it looked at. I haven't taken it to an Autozone/O'Reilley's to have them read the codes for me or not. The BAS/ESP light lit up randomly for no real reason after we had gotten our first bout of icy weather. Could that be a speed sensor? I haven't had the alignment checked on the car in a long while either, and can do that too. I plan on taking it to get the oil changed so Ill have them check the alignment as well to see if that might fix the issue.
The brake switch in my experience needs to be a genuine part and I've had ones fail from the likes of ECP and other places, so go to the dealer as its cheap.
The cruise is also govened by the speed sensors on the wheels, therefore if you have odd size tyres or wear, it will cause the cruise to stop working properly. The ABS is linked to the speed sensors too, so worth checking if there might be some dirt on the end of the sensor first.
Start with the brake switch, start the car and see if the ABS/ETS lights stay off, then watch the dashboard everytime you press the brake to see if this triggers the fault.
If so change the brake switch first and go from there.
