intake??
Old Dec 8, 2008 | 08:39 PM
gartec's Avatar
2001 clk 430
intake??
2001 clk 430
where do i find a intake?
any point in the right direction would be great
Old Dec 9, 2008 | 06:43 AM
xmodrelic's Avatar
2kCLK320
I'm no expert, especially on 430's but you may find what your looking for here
https://mbworld.org/forums/clk-class...t-intakes.html
Old Dec 9, 2008 | 04:48 PM
2PHAST's Avatar
500E Signal Rot
FWIW. I see the original thread talks about the stock CLK320 airbox setup as a good performer. I went through several designs, first using a C36 airbox, which didn't match up to my MAF, then I purchased a full CLK320 airbox for comparison, the top section is almost the identical size, but the bottom section was more restricitve than the bottom section of the C36 airbox. So I Frankensteined the airbox, using the OE top section and the C36 bottom section (with a K&N). I am quite happy with the final results, although I don't have any before/after dynos with the different air intakes (too much time spent on the dyno with the C32 injectors and Unichip piggy back ecu). End result, 270 rwhp.
The bottom of the C36 airbox has a larger secondary intake than the factory CLK box, plus the mouth of the box is also larger and thus can flow more air.
Old Dec 9, 2008 | 06:53 PM
xmodrelic's Avatar
2kCLK320
So your getting 270 at the wheels with injectors, ecu upgrade and modified airbox? On a 320? I'm in the process of similar upgrades and was hoping for that at the crank(Sorry for the hijack).
Old Dec 9, 2008 | 07:36 PM
2PHAST's Avatar
500E Signal Rot
Haha, you need a bit more to get that kind of power
Old Dec 10, 2008 | 08:00 AM
xmodrelic's Avatar
2kCLK320
well a guy can dream cant he. I did say hoping
