Mixing different brake pads
I need to replace the rear brake pads on my CLK. Would it be a problem if I changed my rear's to Porterfield and still have the factory pads in front?
Also, does anyone have any other info/tips on changing the rear brake pads. I found some info at http://www.mercedesshop.com/e_class_brakejob.htm
Thanks in advance.
J
Thanks in advance.
J
2000 Clk 430
you can mix to an extent. I don't think you can get Porterfields in the rear.
Besides they are crap. Upgrade the fronts to a better pad and use the oem pads in the rear. Easy to change...
