98 CLK 320 BAS ASR Braking assistance?
Old Dec 29, 2008 | 11:45 PM
OGCLK320's Avatar
2004 E55 AMG, 2008 G55 AMG
This is my first post. i just wanted to know if anyone else experiences this problem. the light always comes on. it doesn't effect driving conditions except my cruise control will not work, until i restart my car. does anyone else experience this? or why the BAS ASR system comes on at all? thanks for any help you have!
Old Dec 30, 2008 | 12:10 AM
Ausmbtech's Avatar
190D 2.5 (x2), 190E 2.6, W202 C240,W202 C43 (C55), W210 E55, W212 E250CDI
When the light is on then the BAS/ASR has recognised that a fault exists and the system is deactivated. BAS is the brake assist system to reduce stopping distances in an emergency situation and ASR is bascily traction control (automatic skid regulation).
You'll need to get your car scanned for code to help determine where the fault lies. Common fault are the stop lamp switch (75% of the time) and a damaged BAS control unit (usually water damaged)
Old Dec 30, 2008 | 12:25 AM
OGCLK320's Avatar
thank you!
Old Jan 12, 2009 | 04:44 PM
rjlawlor646's Avatar
2001 CLK 320
when does the light come on? when you step on the brake? see if your brake lights are working..mine weren't and the problem was the brake light switch behind the brake pedal..i took it out and cleaned out the metal conections! works like new now
Old Jun 18, 2010 | 03:12 PM
dc1225's Avatar
2016 GL 450
does anyone know what P0400 and P0700 codes are related to BAS, BAS ASR lights?
Old Jun 29, 2010 | 11:43 PM
CLKblackout320's Avatar
CLK320
i got the same problem my BAS/ASR pop up all the time sometime it doesnt even pop up at all, and it usually pops up when i hit a pot hole in the rood or a bump, but i also have my rear passenger side secoundary parking light out that could be just the BAS, a dealer told me change the light bulb and see what happens, about to change and let you no
