Kompressor not working
Old Jan 17, 2009 | 02:56 PM
canitbedone's Avatar
clk 230k
Exclamation Kompressor not working
have a mb clk 230k the car when i start it up some days it has lots and lots of power for about 5 mins after 5 mins the power is ok but just not as much power. help . happens a lot when cold out side and after i fill it up with petrol sum times is it the Kompressor not working how do i know
Old Jan 17, 2009 | 03:00 PM
C43AMG's Avatar
Veteran: Army
98 Black C43 , 12’ ML 350 Blutec
When was the last time the fuel filter was changed ?
Old Jan 18, 2009 | 04:09 PM
clk 230k
thanks for all your help will get right on to it i just cleaned the map sensor did not work **** happens will try the filter thanks
Old Jan 18, 2009 | 04:11 PM
C43AMG's Avatar
Veteran: Army
Keep us posted.You might want to check/replace your plugs while you are at it.
Old Jan 19, 2009 | 11:58 AM
clk 230k
put a new fuel filter in today car is the same but i took out the MAP sensor and the car ran the same as when it was in think its that what you think thanks for all your help c43amg
Old Jan 19, 2009 | 01:04 PM
C43AMG's Avatar
Veteran: Army
Did you check the plugs too ?
Old Jan 19, 2009 | 02:45 PM
clk 230k
yes there ok
