OBD Code Fault P0170
Old Jan 20, 2009 | 09:06 AM
billyflama's Avatar
clk 430 / SL500
Hi Guys, newbee 2001 90,000 clk 430.
ck engine on, fault p170, fault reads; Fuel trim Malfunction (bank1), check vacc. leaks or ....(but does not give anymore options)...
Does anyone knows about what should I look for!!! please....
thanks
Billy
Old Jan 20, 2009 | 12:47 PM
sfclk's Avatar
1999 CLK320
have you noticed any misfires? i would try resetting the code if the car seems to run fine.
Old Jan 20, 2009 | 03:43 PM
aliu's Avatar
01 clk55, 99 v70, 99 jetta vr6, 78 280z w/sm blk chevy
Probably going to be an MAF issue. Mine started with just a 0170, then 0170, 0173, etc. Cleaning the MAF and resetting the code helped for a while, but the fault codes came back every couple of months. Finally replaced the MAF, all is good for over a year now.
Old Jan 21, 2009 | 07:35 AM
billyflama's Avatar
clk 430 / SL500
there's a misfire in the motor... I reset the code but still there!!! i'm going to clean the maf, lets hope that ck light goes off !!!! thanks guys !!!
Old Jan 24, 2009 | 12:37 PM
gregory13lil's Avatar
2000 CLK430
I had the same errors even after I replaced the MAF. I finally ended up replacing the front Oxygen sensors and now NO MORE ERRORS and the engine runs perfectly now.
Greg
Old Jan 30, 2009 | 01:52 PM
aliu's Avatar
don't mean to steal this thread.
Hi Greg, how hard was it to get to the 2 front O2 sensors?
Did you use OEM O2 sensors or the universal 4 wire sensors?
If you used the universal 4 wire sensors, which ones, any issues?
I have 2 codes pending P0130, P0150, probably got to take care of that soon.
