Automatic Window Gap when Door Opens
Old Jan 21, 2009 | 12:17 AM
djdorifto's Avatar
My car just started doing this weird thing. Both windows work fine, they go up and down. But on my passenger side when the door opens the window goes down, but it goes a bit too far than what it use to do. It goes down maybe an inch or more down.
Now when I close the door its suppose to roll back up (the window), but it doesn't. It stays right there. I'd have to wait till the passenger closes the door and I have to roll it up manually... I've search a bit but couldn't find a answer.
Anyone know a solution to my problem
Old Jan 21, 2009 | 05:51 PM
gn3's Avatar
gn3
CLK430 Cab 03
Try rebooting your car. Disconnect battery, hold brake pedal for few seconds, reconnect battery. Roll windows down all the way and back up. Make sure you have the radio code if you have OEM deck.
Old Jan 21, 2009 | 07:04 PM
ilcarnefice's Avatar
CLK 320
I have this problem once in a while.. sometimes it happens when I disconnect the battery and sometimes randomly.. Usually to fix it I just put the key to position 2 and roll both windows down and hold for a couple of seconds and then roll them up and hold for a couple of seconds. There are a couple of more in depth posts about this but this usually works for me! Good luck
