Where can i get a cheap but good quality rear camber kit?
Subscribe
Feb 11, 2009 | 04:50 AM
I need a good camber kit (front and rear)but i dont have alot of money iam getting ready to lower my car with h&r springs with 1/2 coil cut on all 4 corners...anyone? thank you
Reply 0
Feb 11, 2009 | 12:53 PM
Defintely spend money on a camber kit. Speedybenz or speedybnz makes and sells camber arms. he's a little slow tho. The quality is fantastic and the camber is fully adjustable...easy install too. There are also some arms on ebay...a little cheaper, but I can't speak to the quality. I hear the kmac kit is pretty painful, so I'd avoid that if I were you.
Reply 0
Feb 11, 2009 | 10:17 PM
lensolo makes some camber arms too, they seemed great. if you cant find it on here. look over on www.m y m bonline.com
Reply 0
Feb 11, 2009 | 11:19 PM
The dealer sells front camber bolts for about $15 each. You need 4.
The rear will not be cheap. If you're having a shop do the work, I'd buy the kmac kit.
Reply 0
Feb 11, 2009 | 11:49 PM
yes, the arms are ONLY for the rear. The rear camber is not adjustable from the factory. I believe you need two camber bolts per side on the front and then 1 camber arm for each side on the rear.
=> 4 camber bolts, 2 camber arms, $$ or time installing
Reply 0
Subscribe
Currently Active Users (1)
