First Major Problem
Took it to my dealer and they said that my
Drag Link Assembly w/ Tie Rods Part Number: 202460505 is shot.
They also recommended I go with a Bilstein Steering Damper.
This is my first major problem with my car.
Any gains of going with a Bilstein Steering Damper over Stock?
Will I need an alignment afterwards?
They did not say anything about needing to have a realignment.
The steering damper is a simple DIY. there's like... two bolts and a shock underneath the car in your steering area.
You don't necessary have to go with Bilstein. Another brand that you can go with is STABILUS. I'm not 100% sure what brand our OEM steering dampers are, but "everyone" says... if you haven't replaced your ORIGINAL steering dampers since the car was bought, be prepared to feel a huge difference. (in a good way of course).
Sorry to hear you had trouble!
I forgot to mention that my Coolant Reservoir Tank is also busted. Go figure, now who has replaced that or even heard of that failing. I got coolant being sprayed over my engine having to refill the tank every 2 weeks.
This looks like a deal http://cgi.ebay.com/ebaymotors/Merce...Q5fAccessories
