manual trans????????
Even an E36 M3 ZF transmission with upgraded flywheel, clutch & pressure plate can easily handle the power (Turbo cars are running the ZF transmissions well up into the 500+HP range) and it has 5 speed ratios that are very well spaced. Also it is much more compact so fitment issues would be alot less. That and you can have M3 transmissions for as low as $500 (some as high as $100). of course at this rate you could just buy an BMW 328 for a few grand (whole car, it shares same transmission as E36 M3) and transplant everything over you need and sell the rest to break even. It may end up costing you nothing for parts.
again, these are just ideas I'm throwing out there.
