Where can i check the power steering fluid level???
Old Mar 8, 2009 | 06:57 PM
OGCLK320's Avatar
2004 E55 AMG, 2008 G55 AMG
Arrow Where can i check the power steering fluid level???
I need to check my PS fluid level. Possibly change it. Can anyone direct me in the right direction on where the fill spot is? or Where i check the level of the fluid? thanks for any help.
Old Mar 10, 2009 | 07:17 AM
A1EK's Avatar
SL 350 R230 (3.7L with AMG Speedshift autobox)
its on the right hand side of the engine and is small black plastic box with a screw lid. At operating temperature, on level ground and with the engine now off unscrew the lid. There is a small plastic dip stick attached to the underside with a min/max level indicators. Make sure you are between the lines, too much fluid is just as bad as too little. The oil to use is only availiable I think through Mercedes Dealer and in the UK is about £10 ($20) approx.
Good Luck
Attached Thumbnails Where can i check the power steering fluid level???-image_190.jpg   Where can i check the power steering fluid level???-image_189.jpg   Where can i check the power steering fluid level???-image_191.jpg
Old Mar 10, 2009 | 11:36 PM
sfclk's Avatar
1999 CLK320
Fluid amount has to be perfect. I had to add a couple ounces to red rid of a noise from the pump.
I think I paid $15 for a quart. One quart is enough to replace the old fluid in the reservoir.
Old Mar 11, 2009 | 08:44 AM
A1EK's Avatar
do u think its worth changing>? I just topped mine up as the hose on the outside was lose
and some was leaking
