Check Engine Light
Old Apr 13, 2009 | 11:35 PM
zaidynot's Avatar
1999 CLK 430 / 2006 CLS500
Check Engine Light
How do i reset the check engine light on a 99 clk430 ?
Old Apr 14, 2009 | 03:15 AM
unlukky's Avatar
2019 CLS450/ 2002 CLK55
Cool
Get an OBDII scanner (I believe you can borrow one at AutoZone).
Read codes (Hopefully you've already fixed what was wrong).
Erase codes.
The CEL light should go out on its own after a few drives or even days when the ECU recognizes that there isn't a fault anymore FYI.
Old Apr 14, 2009 | 12:19 PM
da_guitarist's Avatar
Current: AMG GT-C. Sold: 01 CLK55, 00 ML55, 01 ML55, 06 E55
I believe you can disconnect the battery for about 30 seconds and it resets also. might wanna search first in case it clears settings
Old Apr 14, 2009 | 12:46 PM
zaidynot's Avatar
Thank you
I will try that
Old Apr 14, 2009 | 12:54 PM
DropTop430's Avatar
02 clk 430 cabrio
find out what the codes are before u reset it !!!!!! dont drive with the check engine light on for awhile cause then u could always ruin something else and fix the first problem and then have the light off for a few weeks and have it come back on dued to the second problem that u computer didnt get to read......thats what happened with me lol
Old Apr 15, 2009 | 01:39 AM
unlukky's Avatar
Cool
Agreed. I wasnt very clear in my first response.
Definitely pull codes and fix problem. (possibly intermittent or one time occurance) However, if the ECU has not reset itself on its own then the problem probably still exists. Don't ignore, you'll get the snowball effect and regret it.
