CLK 320 with 430 Wheels...
Old Feb 5, 2003 | 08:46 AM
Bouncer's Avatar
2001 CLK 320
I own a 99' CLK 320. Getting rid of the horrible stock Rims and upgrading to the standard 430 AMG 17" (17X7.5 front 17X8.5 rear) rims.
Are there any bolt differences or required shims or anything I need to be aware of?
Regards,
-Bouncer-
Old Feb 5, 2003 | 12:43 PM
Bouncer's Avatar
2001 CLK 320
Hello?
Can anyone answer this, please. Simple yes/no would do.
Thanks much,
-Bouncer-
Old Feb 5, 2003 | 01:23 PM
Ted Baldwin's Avatar
300ce
.......No. It goes on just fine
Ted
Old Feb 5, 2003 | 01:25 PM
nubomb's Avatar
Wink
No...no no I mean Yes...or better yet possibly or maybe.
Chil out, someone well informed will answer your question, anyone can answer yes or no and be completely wrong.
Oh by the way I would say Yes. But that really doesnt answer your question, yes it will fit but no on the bolt difference.
Old Feb 5, 2003 | 01:29 PM
Adonis's Avatar
CLK 320
bouncer
in order to have a perfect fit you need to match and verify that the wheels you are getting match the wheels that you have. Most stock 320's wheels come with a
bolt pattern = 5x112
offset = 35
hub bore = 66.56
Make sure that the 430 wheels that you are getting match this.
Old Feb 5, 2003 | 03:06 PM
x15jq's Avatar
Ull need different bolts the ones off the 99 clk are really short.
Old Feb 18, 2003 | 01:17 PM
mikeyclk's Avatar
clk 320
Is it expensive to replace the bolts or is this an easy modification.
I have a '99 CLK320 with stock rims that I would also like to replace with something more attractive. Any suggestiions for something relatively inexpensive that would resemble the standard wheels on later year 320's. I have brand new tires so I would like to re-use them if possible.???
