finally lowered....
Old Jun 5, 2009 | 03:48 PM
anchuidimay's Avatar
2002 Clk 430, 09 X5
finally lowered....
as i just lowered my car... my camber is WAY off.....what would u guys rather choose? kmacs or lensolo/speedybenz camber arms to fix? what are the advantages and disadvantages of going either route? thanks.......now some pics.......sorry for the crappy lighting but it was raining out....
<img src="">
<img src="">
<img src="">
<img src="">
<img src="">
<img src="">
Old Jun 5, 2009 | 05:50 PM
vizionclk430's Avatar
2002 clk430
Sorry I don't have anything for camber adjustment so can't help in that department but it Looks good get up some better pics when the wheather clears up. What is your specs on wheels tires and suspension.
Old Jun 5, 2009 | 06:32 PM
Ghostrider's Avatar
01 CLK 430
Those are some mighty fine looking wheels.
Old Jun 5, 2009 | 09:11 PM
2002 Clk 430, 09 X5
I'm running 19's 8.5 front 9.5 rears...235/30/19 fronts 265/30/19 rear....offsets off a w203 with 15mm spacers in the rear...dropped on HR....I'm getting some rubbing on the passenger rear so I might change to 12mm spacers..
Old Jun 5, 2009 | 11:30 PM
2002 clk430
I'm in the market for spacers so I might be able to grab the 15mm ones off of you once I measure and think they will fit.
Old Jun 6, 2009 | 02:37 AM
sfclk's Avatar
1999 CLK320
camber doesn't look too bad. i would just get the toe checked out. which pads did you have put in? 1s?
i'm also willing to take the spacers off your hands.
Old Jun 6, 2009 | 05:37 AM
J56BP's Avatar
2002 CLK 430
it is bad i bet its negativ 0.3 or 4........will eats the inside vall in the hurry....i had the same look
nice drop tho........but what i can't figure out why mine didn't lowered that much used the same set up H&R #1 pad....but i still have like 1 1/2 finger gap? drives me nutz did u cut the spring?
i bet ur driver side lower then passenger side, same with mine no clue why tho. u guys think it makes a diff if i turn the spring so its seats inside the perch?
Old Jun 6, 2009 | 08:12 AM
A1EK's Avatar
SL 350 R230 (3.7L with AMG Speedshift autobox)
Good work my friend, loving your deep dish rears ! are they chromed lip?
I have the Eibach Pro kit and my rears have 15mm spacers on. From your photo the camber looks to be the same as mine, but I know you cant judge it that way. I was lucky and got the tiny adjustment I needed by the garage, as they slackened off and re-tightened the arm bolts etc. I have perfect wear on my rears and not on the edges.!
(PS my car is the one on the right I parked next to a standard CLK to show the difference on the rears)
Good luck
Attached Thumbnails finally lowered....-p1020529.jpg   finally lowered....-p1020523.jpg
Old Jun 6, 2009 | 11:39 AM
DropTop208's Avatar
02 CLK 430 Cab
I had the K-mac kit on my car, and they were useless. specially the rear. Did nothing for me. I bought the camber arms from lensolo. Fits perfect, and adjusted my camber to spec.
Old Jun 6, 2009 | 12:40 PM
2002 Clk 430, 09 X5
thanks...but i saw that ur selling ur own....can i ask why?....i love the look the daytonas give my car
the rears are #1 and front is #3....i might change my rears to #2 cuz im rubbing and will probably rub even more once my springs settle....
never cut my springs....my driver side is lower than my passenger buut not really noticable....id say less then 1/4 inch....u shouldve seen my car before my drop....2 fingers front 3 in the rear...it looked so funny....specially with 19's on...
Good luck
thanks ...they are actually polished lips...they were trashed when i got them and tried to bring them back to life...but my driver side rear camber is worse than my passenger for some reason....my camber before i dropped was -1.25 degrees and from the looks of it, its much worse now...nice car btw
will look into that...thanks
Old Jun 6, 2009 | 02:13 PM
tastoto's Avatar
ck430 2002
I like the wheels what are they the car is looking nice
Old Jun 6, 2009 | 02:22 PM
2002 Clk 430, 09 X5
they are iforged daytonas......thanks
Old Jun 8, 2009 | 12:54 AM
2002 Clk 430, 09 X5
ok so i decided on lensolo arms....but a couple of questions...do u think i will rub on the fender if i adjust camber??? or should i go with a higher spring pad, as i was rubbing on my passenger rear fender lining. i used a heat gun to push it back some what and it now clears a little bit but im still hearing a rubbing noise and im not sure where it's coming from....not sure if im rubbing somewhere and i cant see it...or my stock shocks are compressing to much and making the noise as its only over bumps...its driving me crazy....any info would help ALOT
Old Jun 8, 2009 | 01:08 AM
sfclk's Avatar
1999 CLK320
adjusting for less rear negative camber would probably cause more clearance issues. hopefully, a complete fender roll would clear your setup.
to find the rubbing, i would clean the wheel well and anywhere else the tires could rub. then check for tire shavings on suspected clearance problem spots.
i noticed a rub that sounded like tire to plastic rubbing and pushed back the left wheel splash guard and haven't heard it rub since.
Old Jun 8, 2009 | 01:13 AM
2002 Clk 430, 09 X5
yeah i figured i would start to rub on my fender if i fixed the camber...thats why i was thinking of using a higher spring pad to lift the car a bit to clear the tire under the fender....i pushed back the lining and saw a groove where the rim was rubbing...i covered it with duct tape and drove around to see if it still rubbed and it doesnt in that spot....i took off the wheel and see nothing else where it could rub.....
Old Jun 9, 2009 | 01:39 AM
AMGMB's Avatar
1999 Mercedes Benz CLK430
Dam loving the rims!! Car looks NICE!!
Old Jun 9, 2009 | 01:44 AM
sfclk's Avatar
1999 CLK320
wouldn't a higher ride height just avoid rubbing when suspension is compressed? the travel is still the exact same.
Old Jun 9, 2009 | 01:48 AM
2002 Clk 430, 09 X5
heres my dilema.....im rubbing on the inside of the wheel well....if i dont raise the car a bit and fix camber....i would no longer rub inside the wheel well but instead start to rub constantly on my fender lip....if i use a higher spring pad to raise the car and fix camber...i shouldnt rub on the wheel well or fender lip....thats what im thinking....or i could roll my fenders but im scared it might not be enough....
