Need help with tire sizes
Old Feb 18, 2003 | 11:47 PM
Adonis's Avatar
CLK 320
i was thinking of buying 7.5 inch wide wheels and i was hoping you could help me figure out what's the widest tire i can put on 7.5 inch wheels
thanks
Old Feb 19, 2003 | 05:27 AM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
Re: Need help with tire sizes
thanks
You need to give more information, like wheel diameter, what profile tire you would like to run, etc.
Also, this will vary by manufacturer, so a 235 tire may fit in one instance and only a 225 in another instance.
Just as an example, on one of my Mercedes I have a 315 wide tire running on an 8" wide rim. This is the preferred setup, so it's not like I am pushing it to do this. (If this sounds weird to you, then you should quickly understand that without more information, things taken out of context can appear strange.)
-s-
Old Feb 19, 2003 | 06:24 AM
Adonis's Avatar
CLK 320
Re: Re: Need help with tire sizes
-s-
The wheels I want are 18x7.5 all around I would like to know how wide of a tire i can put on front and rears of my CLK? Which ever tire manufacturer fits the widest tire is who i'll go with.
Old Feb 19, 2003 | 07:51 AM
CiLKY's Avatar
13 S550 4Matic
235 is about the widest I'd go on a 7.5" rim you could run that front and rear if the offset was correct.
Old Feb 19, 2003 | 05:10 PM
scorchie's Avatar
Bridgestone S03 235/40R18 should NOT be mounted to 7.5" rim.
Bridgestone S02 235/40R18 should NOT be mounted to 7.5" rim.
Dunlop SP9000 235/40R18 should NOT be mounted to 7.5" rim.
Goodyear Eagle F1 GS-D3 235/40R18 should NOT be mounted to 7.5" rim.
Kumho Ecsta MX 235/40R18 should NOT be mounted to 7.5" rim.
Michelin Pilot Sport, Pirelli PZero Rosso, Yokohama AVS Sport, and the list goes on... are recommended against mounting on 7.5" rim.
So I am not sure what brand YOU think will fit properly. Can you help me out and let me know? Thanks!
-s-
