Carlsson spings/dampeners/spring pads
Thanks!
Tim
Any help here is greatly appreciated!
Thanks for the replies. I have another question then: I cannot seem to locate the "bumps" on my spring pads to figure out which ones I have. I've tried looking into the wheel well and see nothing resembling "bumps."
Tim
You may be able to see yours by:
Remove your wheel
Locate the Spring
Look inside the spring at the top for a rubber pad
The bumps are on the pad.
You will only need to check 1 per axle.
