alignment problems
Old Aug 19, 2009 | 02:53 AM
akuzu's Avatar
2000 CLK 430
People with 19's on there CLK430 alignment problems, can u please help
hey guys ever seens i got 19's on my 2000 CLK 430 I had alignment problems it always wears out outer edge of my tires and Mb dealer in my town cant fix it because its not OEM wheels I do live in a small town of west texas so the Mb dealer here is a joke so do yall have any ideas how to fix this problem.
Old Aug 19, 2009 | 10:36 AM
Ghostrider's Avatar
01 CLK 430
Is your car lowered? If so, how and how much?
Old Aug 19, 2009 | 11:37 AM
akuzu's Avatar
2000 CLK 430
Unhappy
car isnt lowered, can u still help?
Old Aug 19, 2009 | 04:46 PM
billyflama's Avatar
clk 430 / SL500
front or rear ???
Old Aug 19, 2009 | 06:18 PM
bobbyjo9's Avatar
02 clk 55, 13 GL 450
Im guessin your talking fronts?? 19's will amplify any problems you have so that may be why they are showing now. whats your mileage and front end history? Our suspensions wear out and with 19's that will be faster.
Old Aug 19, 2009 | 07:08 PM
akuzu's Avatar
2000 CLK 430
I have 89,000 miles on the car and never had a front end collision but I did get rear ended ones. Only thing it did was crack the rear bumper and after that I had alignment done on the car and that was with my stock rims on. What part of the suspension wear do u think would cause to this?
Old Aug 20, 2009 | 02:35 PM
bobbyjo9's Avatar
Id start with the easiest and most common... ball joints. at that milage they are toast. You will have other items to look at such as lower control bushings and dampner also. Last item to check is the drag link but work your ways backwards to that. Even with the 208 outdated steering, you will be surprised how tight and responsive it is when back in spec.
Old Aug 22, 2009 | 07:31 PM
anisamy1's Avatar
Mercedes AMG
Lower control bushings and dampner really affects this thing, or not?
Old Aug 25, 2009 | 06:56 PM
akuzu's Avatar
2000 CLK 430
It seems like i got alot of work to do.
Old Aug 25, 2009 | 07:07 PM
bobbyjo9's Avatar
bushings yes, damper will just take out vibration and wander but nothing for wear
Yeah but it is all straight forward and not very difficult. You will need an alignment after you are done though
Old Aug 25, 2009 | 08:05 PM
sfclk's Avatar
1999 CLK320
Outer edge wear on the front only? Sounds like toe specs are out.
Old Aug 25, 2009 | 08:33 PM
akuzu's Avatar
2000 CLK 430
ya I will change all that and see what happens.
Old Aug 25, 2009 | 08:34 PM
akuzu's Avatar
2000 CLK 430
Say brother can u explain what is a toe spec and how to fix it?
Old Aug 26, 2009 | 04:44 PM
bobbyjo9's Avatar
thats a spec best left to the alignment shop and will only cause feathered wear across the face of the tire. Inside/outside edge wear is from bad camber adjustment.
Old Aug 28, 2009 | 02:46 AM
akuzu's Avatar
2000 CLK 430
K thx bro.
