exhaust for my CLK and water injection report
Old Feb 23, 2003 | 12:22 PM
goodman888's Avatar
MB CLK320
1 question and 1 report here.
I want to increase the torque and response of my CLK320 Cab esp before 3000 rpm. After 3000rpm, it's great and I dont need better.
Any exhaust fit for this purpose? As I heard, most exhausts increase the middle power band but decrease the low power band.
And, I installed the water injection system. I'm now testing it with water and later will try methanol/water mixture.
I feel the car faster and the response much better esp during start-up and uphill. However, no increase for 0-100 acceleration.
Will try methanol/water mixture later and stay tuned.
Old Feb 25, 2003 | 07:57 PM
theine's Avatar
2014 GLK250 BlueTec & 2009 ML320 BlueTec
Exclamation
What is the water injection system??
Old Feb 25, 2003 | 08:43 PM
goodman888's Avatar
MB CLK320
Pls see http://www.ahfung.com/car/clk320-02.html
I put the photo and comment ther.
Old Feb 25, 2003 | 09:39 PM
J Lucas's Avatar
Am i the only one who thinks that is the most ridiculous thing ever created?
Old Feb 26, 2003 | 01:02 AM
Turbo2's Avatar
Water Injection, or alchocol/propane injection is really only necessary on turbocharged or supercharged cars, I see no real need to use it on a normally aspirated engine. The purpose is to cool the intake charge after it has come through the intercooler. With this, in general you are usually able to run a leaner A/F ratio, more boost and your engine is less likely to detonate. Propane or alchocol injection can effectively actually raise the octane of fuel, once again allowing higher boost with less detonation.
I would have to agree with "J Lucas", I do not see why you would use this on a normally aspirated engine, especially the 3.2L V6.
Old Feb 26, 2003 | 02:30 AM
goodman888's Avatar
MB CLK320
I read many documents and research papers about Water Injection. They DO also help NA engines, but not as much as Turbo engines -- that's true.
Adding water, theoretically, can save some fuel. But I havent tested it on my car yet. Adding methanol/water mixture, by theory again, can increase power. I shall test this later and
let you know.
But it's certain that the response of the car is better after installing the water injection.
Old Mar 3, 2003 | 02:01 AM
krisk85's Avatar
supercharged ie clk 230k in EU or the new 209 clk 200k might have a bit of a use for this water injection. Would like to see some results off one of those cars.
kris
