Big Problem...need Help/advice
Old Mar 1, 2003 | 12:38 PM
cgmike10's Avatar
CLK320, ML320, 300TE
I got a transmission fluid change on my 98 clk320. Used all original parts/fluid. Drove out of the shop, and as soon as the car reaches fourth gear, it goes to neutral. They say it is going to cost over $1500 to fix. What could the problem be? I have to leave the shifter in 3rd gear if I want to drive the car at all because after third it goes into neutral. Car has 86k miles
they only put 7 quarts in...is that enough?
Also downshifts feel like a strong boom.
I NEED HELP!!!
Old Mar 1, 2003 | 11:18 PM
RJC's Avatar
RJC
Various
Re: Big Problem...need Help/advice
I NEED HELP!!!
Get a second and third opinion(if nessc). Could be an electronics problem with the trans not mechanical. Why did the fluid change are they reputable? Did the car drive ok before the change, did they use the right fluid and why 1500 to fix, what did they say is wrong?
Old Mar 2, 2003 | 01:28 AM
cgmike10's Avatar
car needed the change
The car definitely needed the change. Shifting was feeling like stick shift almost. After the change it drove a few blocks good, then the problem occured after a loud bang. The place is very reputable, however, I found out 9 quarts instead of 7 is reccomended on this tranny. Sounds like they were trying to create a problem so I would go back to them.
They said something about a valve...maybe a body valve or something I dont remember exactly but they said closer to 2000 to fix now. What I am going to do is add another 2 quarts of fluid (all fluid/parts used were original mb).
They also reset adaptation parameters. Maybe that caused a problem?
In any case, legal action is not out of the question and I am certainly not paying them for a fluid change as they reccomended it to me and I did not ask for it.
