Replace rubber grommet around trunk lock
Old Oct 28, 2009 | 03:09 PM
CLKBOB's Avatar
1999 CLK 320
Have a '99 CLK: The rubber grommet around the trunk lock is coming apart. A replacement grommet cost $3.00. The dealer wants $100 to do the labor. Is this something that can be done rather easily or should I check with a body repair shop to get a better price for the labor?
Old Oct 28, 2009 | 05:47 PM
VIPclk320's Avatar
CLK W208
it is ver easy, open the trunk and on your lock assembly you will see two bolts, take those off and the lock assembly slides out replace the groumet slide the lock assembly back in, put the bolts on and and close your trunk get in your car and drive by the dealer that quoted you $100 and give them the MIDDLE DIGIT and have yourself a nice day.
Old Oct 28, 2009 | 06:18 PM
CLKBOB's Avatar
1999 CLK 320
Thank, I thought it might be that simple, was just concern that there might be an alignment issue with the lock. I will scratch mark the bolt locations on the lock housing before loosing and removing the bolts.
Old Nov 4, 2009 | 08:25 PM
rjlawlor646's Avatar
2001 CLK 320
do they make replacements that are the same color as the car? not rubber? I think the black rubber is verrry ugly
Old Nov 5, 2009 | 11:39 AM
CLKBOB's Avatar
1999 CLK 320
Red face
To the best of my knowledge, Black is the only color. Never thought to ask, since the OEM was black.
Removal of the old grommet (they now call it a seal) and installation of the new one was very easy. It took all of 15 minutes from the time I loosened the lock bolts till the time I closed the truck and admired my handy work. I then took my wife to dinner with the $100 I didn't give the dealer.
