what are the signs?
Old Dec 7, 2009 | 11:51 AM
big_mike1979's Avatar
CLK 320 (2001) and 2015 GTR
what are the signs?
of havin bad shocks?
Old Dec 7, 2009 | 07:46 PM
anchuidimay's Avatar
2002 Clk 430, 09 X5
if u push on ur car or drive over a bump and ur car bounces more then 2-3 times
Old Dec 7, 2009 | 09:56 PM
its hard to push on my car since my springs are compressed due to the drop.
but when im driving , it can hear like something is clicking like pa pa(sound), like there is no air in the shocks and when it hit a dip in the road, i can feel lthat the shock hits..i could be wrong but i wanted to know b4 i order the damn shock
Old Dec 7, 2009 | 10:48 PM
2002 Clk 430, 09 X5
if u drive and the car just continually bounces more than usual after a bump, the shocks are blown...it'll be hard to tell if its only coming from 1 corner though
Old Dec 8, 2009 | 02:26 AM
vickenma's Avatar
2000 CLK320 Coupe & 2010 GLK350
its hard to tell but on the long term it can effect your tire wear [i.e cupping, uneven wear, etc.] you might feel like your car takes longer to brake and nose dives easily. you're right, the compressed springs will make it harder to feel any bounce in the car. you can also visually inspect them to see if there is any moisture around the shock. my suggestion is to change them. most shocks last about 50-60k miles. hope that helps
Old Dec 8, 2009 | 11:38 AM
dlbehrns's Avatar
99CLK320,
from what you are describing it sounds like something is loose. a worn shock won't necessarily make a sound. the car, like the previous posters described, will be to handle differently.
Old Dec 8, 2009 | 01:01 PM
Chappy's Avatar
AMG
If leaking, they'll need replacement.
