Hazard Lights have a mind of their own
Old Jan 5, 2010 | 06:12 PM
prc6's Avatar
CLK 230 K
Hi All,
Very new to the world of Mercedes and decided to go for a clk 230 from my local scrap yard that needs a bit of consmetic work to get it back to its former glory.
So the issue that i have at the moment with the car seems to be that the harzard lights have a mind of their own. I have had a search throught the forum and not seen anything similar mentioned. Basically the hazard lights come on and off on there own. Now i am not sure if this makes any difference but currently i have not got a remote for the vehicle as the one i have is faulty therefore i have been using the blade key to get in the car. So could this be the alarm going off ?
Another thing that i have notice is that when the hazard lights are flashing by themselves they flash at a slower rate than when you engage the hazard warning switch.
Any help or pointer much appreciated, also if you need any more information please ask and i will try to supply it.
Pete
Old Jan 5, 2010 | 07:29 PM
JapSpec's Avatar
W208 CLK320
sounds like a relay issue. Almost like its tripping itself and not disconnecting.
Old Jan 6, 2010 | 10:00 AM
prc6's Avatar
CLK 230 K
Thanksa for the reply JapSpec, i did try to have a look for the relay with out much luck. I check under the bonet behind the fuses where i have found some relays but when the lights are falshing i am not able to work out which one is for the lights. do you know the relay number at all / is this the correct location for it?
Old Mar 22, 2020 | 02:18 PM
convicted's Avatar
1998 CLK 320
I know this is a decade old thread, but can anyone tell me how to remove the hazard light switch?
Maybe we can make this thread useful.
Thanks,
