Will 18" wheels fit on a 99 clk 230
clk 230 kompressor, jeep cherokee, alfa romeo gtv, fzr 1000 exup.
Hi,
I am sure that this will have been asked before but I couldn't find an answer using the site search.
I have a 99 clk 230 that is on 16" wheels
I am thinking of upgrading to 18" wheels and was wondering of there would be any problems.
I am looking at fitting 18x8.5 with 225 40 18 tyres on the front and 18x9.5 with 255 35 18 wheels on the back.
I have been told that they should fit by the shop but wanted to check first.
Also would I still be able to fit lower suspenion with these fitted.
Cheers for any help.
2005 c55
Are you putting on other mercedes rims on this car as I have been trying to figure out if the later model rims will fit on my w208 and have not found it out yet. Would sure hate to buy a nice set and find out they wont fit.
Hi,
For me I have the same tyres as you, I have also lowered my car on Eibachs with minimal pads and dont get any rubbing. I have added rear 18mm spacers to the rear to keep the look tight.!
The largest tyres I have had that fitted were 265 x 40 x 18" on the rears, but I got rid of them as they looked too big and I prefer the little stretch you get with the 255. I have also just gone wider on the front to 235 x 40 x 18".
Good Luck.
to answer rrich49123. no i have been looking at some wolfrace alloys.
thanks to A1Ek for the info. Out of intreset have the wheels and lowered suspesion made much difference to the handling?
handeling is tighter and yet the ride is much the same, thanks to the progressive Eibach coils
2013 FIAT Abarth 500
Not to hijack this thread but it's a pretty easy question I thought someone could answer:
I've scoured the internet for weights on the CLK 320 wheels (style 65245) and can't find any...anybody know weights per wheel? 16x7, if that helps.
these are the ones i have bought, but in silver.
http://cgi.ebay.co.uk/18-BLACK-SHARK...item1c0f95fff6
Second choice is to use copius amounts of polish and wax to seal againts the elements !
Good luck
Thanks for the advice, I will look at giving them a couple of extra coats of laquer before I fit them.
2000 CLK430 Cabriolet
Ordered Tire/Rims from Tirerack, Order Date: 10/28/08
4 18x8 ASA JH9 BDC In Stock $159.00 $636.00
4 235/40ZR-18 Goodyear Eagle GT XL $134.00 $536.00
Shipping: $123.85
Order Total Including Shipping: $1,295.85
I have the same size tires on all 4 corners, which means stepped up a bit up front, and down a bit in rear. Used a snipper to trim about 1/4 inch from a plastic vent/louver inside the front fender well. Problem solved and don't have to mess with two different tire sizes--it isn't a Ferrari.
Shipping: $123.85
CLK 230komp
18's will fit. Got 225/40/18 front & 245/40/18's on the back.
Looks cool but I think it needs a drop.
ahhhhhh $1200 for 4 rims & tyres.. If only...
We get ripped off here in the UK!!
