HELP!! BRakes PAds advice! CLKFAN! HEARSH!! CHIME IN PLS!
Old Feb 15, 2010 | 02:40 PM
BKzCLK430's Avatar
2001 CLK430
hi! i need to change my brake pads and i want to upgrade the rotors to crossed drilled.. where do i go? can someone advise me!!
Old Feb 16, 2010 | 03:21 AM
2PRECISE's Avatar
clk55 amg
check brembo, they have big rotor kits the retain stock calipers.... very cheap and definately worth it. And they r the full floating rotors.
Old Feb 16, 2010 | 10:13 AM
dlbehrns's Avatar
99CLK320,
http://www.msgroup.org/forums/mtt/topic.asp?TOPIC_ID=1342
There are three types of brake rotors: solid, semifloating, and full floating. With a solid rotor a single piece of metal is bolted to the wheel. With semifloating, you have a center piece and a separate outer part that the brake pads touch and the two are connected by a bunch of round "buttons" that allow a small amount of movement between the two. With full floating, the braking surface is relatively loose so that it can move around to hopefully become in perfect alignment with the pads. Full floating rotors are less likely to pulse than solid or semifloating rotors. Most race bikes have full floating rotors. Full floating rotors make noise at low speeds as the parts move around, since they're kind of loose. Semifloating rotors don't make the noise.
