koni shocks??
THanks
David, did it take the same amount of time to install spring as supposed to change the pads number?
www.koni-na.com
Go to site map, then to adjustment.
I have H&R springs with Koni sport adjustable shocks. When I installed the Koni's I put them in the +2 setting, they come soft + 3 settings. I had to return to soft because the ride was to harsh.
www.koni-na.com
I heard that some people say if you get H&R usually you get Bilstein shocks, which is a stiff shock. Is that right?
Does the setting in shock really affect your performance (like body roll)?
The shocks for the CLK are 26 series, so they have soft + 2 settings not 3. The Bilsteins are not adjustable, so if you don't like them, you are stuck with them.
H&R with Koni's for 1.5" drop or H&R cup kit for 2" drop is the best choice in my opinion, of course if you are willing to spend more money, you can go with the Kleeman sensitive suspension kit, which I don't how much is it.
Like I said I have Koni sport shocks, and for me the +2 setting was too harsh, so I wen't back to soft, which is still stiffer than stock and gives me a performance ride.
Thanks Theine.
With the Kleeman sensitive suspension, is it any better than regular coil over or the cup kit?
Theine: I just had Koni's installed and the instructions show that the settings vary in a 0, 1, or 2. I didnt see a +2 or +3. I put mine on 1 but i want to go softer so does that mean i should go to a 2 or 0?
very cheap.. nice people great service..
got them for under $400
www.puremotorsport.com
Theine: where did you get your shocks from? I just asked my buddy to get me the shocks but I think they are pretty darn expensive. $130 F and $150R. Is the price reasonable
THanks,
Solihin
hinhin: as for the koni shocks are your prices for each front$130 and each rear$150?
If the prices are around 300 to 400 and the item is the same (Koni sport shock), maybe I should go with Tirerack, so we have a long lasting forum. :-)
Thanks guys for all your helps.
Solihin
Koni's or Bilstien? Which combo will achieve great performance without sacrificing ride? H&R Bilstien or H&R Koni? I know ride will suffer, and that is why I like the idea behind the Koni adjustables. Also, which setting would achieve what I am asking?
