oil leak from engine
Old Feb 27, 2010 | 10:43 PM
yakko31's Avatar
clk320
Hi everyone i was told by my mechanic that i have a oil leak coming from the front or back of my engine don't remeber but i do remember him telling me that it a plastic cap that needs to be replace like a seal or something need help with this one if anyone knows what he is talking about please en ligthen me thanks
clk 320 1998
Old Mar 1, 2010 | 10:15 PM
wnycec's Avatar
2000 CLK 430
Might be your transmission fluid leaking from the transmission plug on the transmission which has a wire which leads back to your TCU. Be careful is this is the case, could lead to problems in gear changing etc when your transmission fluid dips low enough. Also, the transmission fluid could follow the wire into the cabin and down into the TCU where it could fry the part and then your stuck buying a new one which could be big bucks!
GL
Old Mar 2, 2010 | 07:45 AM
moondust's Avatar
2004 CLK 240
Originally Posted by yakko31
.........if anyone knows what he is talking about please en ligthen me thanks clk 320 1998
wyncec is quite right about the connector seal in the gearbox. They have a history of leaking ATF.
But your comment above shows how important it is to get your mechanic to WRITE DOWN anything that he is advising you about, so that you can understand it later. You clearly don't know much about cars and the sort of problems that this MB model is prone to.....
