How to retune ecu?
This is my first post, I just got myself a nice 1998 CLK230 Kompressor.
Looking to upgrade the pulley and retuning the ecu.
Now I'm an auto engineer, I like to do everything myself. In some of my previous cars to retune the ECU, what I had to do was replace a chip in the ecu with one that I've retuned with a eeprom programmer through my computer. Needed the definition flies and what not for the specific car.
Other cars I've had, I just needed the correct software and interface cable and I could reflash the memory of the ecu directly from the laptop through the diagnostic port.
Can someone point me in the right direction of software/hardware needed to retune the W208 CLK230 komp ecu?
Also anyone know of a place that sells just the pullys?
Thanks guys.
Probably one of the silliest things you can do. If your car is bone stock then I can understand as each car SHOULD be the same.
But if your planning mods you need it done specifically for your car, tuned either on a dyno or on the road.
Anyways I've been on a few merc forums and it doesn't seem like anyone really knows how to do this, I guess the merc community is that big on DIY stuff, understandable though not really a car people go crazy with modding, hard to find good info about this stuff.
There are plenty of companies that will do a custom tune on a dyno. You just have to find one near you with good customer feedback.
Hence why I'm trying to track down the required equipment/software to do this with mercs but having no such luck!
If anyone knows of the software that the tuners use, or a name of a piggy back ecu. I would rather keep the stock system inplace instead of using a piggy back or an aftermarket ecu all together. But its looking like I might have to go down that way.
Once you makes severe changes to your car, there is no way that someone in a workshop with nothing but your ECU can make a good tune. Since they don't have your car and reading its values, theres no way of them knowing how much your engine flows under different loads and when its going to knock etc... The can do it, but it will be an extremely safe tune, retarded timing, very rich fuel etc, and your car will make no where near as much power as if it was done on a dyne (rolling road as some people call it)
Then if you go and change your car again, to get the best out of it, yup off to the dyno again... so over the life of modding your car, you could easily spend thousands of dollars on tuning.
anyones, so if anyone knows anything please chime in!!
thanks again.
http://www.inmotionusa.com/mercedesgraphs.html
When you are tuning your car, the standard O2 sensor is just a narrowband sensor, it can read fuel ratios around 1 lambda (14.7 for petrol) and really not much else.
Narrow bands are only good for letting your computer know if its running rich or lean, not the actual value.
When you replace your standard narrowband O2 with a wideband O2, you need a wideband controller (step in innovate) to take that wideband signal and convert it to a number that you can use.
So now with a wideband you can see the exact fuel ratio your car is running, you can see if its rich like 10.8:1 or lean as 18:1. The range depends on the sensor/controller normally.
Then with the tuning software you can adjust your fuel maps to inject more or less fuel as required and you use the wideband controller as your feedback to your fuel ratios.
I use the techedge controller myself, have used it on several of my cars and have no complaints with it what so ever. Have never used the innovate, but at the end of the day they do the same thing.
The techedge can simulate a narrowband, so I put my wideband in place of my narrow band, feed the signal back to the controller then used the controller to simulate a narrowband signal and feed that into the ecu so the car can run normally. I think most controllers have this as a feature.
More then happy to help, maybe ill create a quick write up on the basics of how the combustion process works then people can get a better understanding of how fuel ratios and spark timing affects power, once you know the basics it doesn't take much to work out how a car should be tuned.
Also as fair as I know the star diagnostic is just that, a diagnostic tool, it doesn't let you change any map tables in the ecu. No dealer ever has this power. Thats something thats reserved for Powertrain engineers.... and tuners
In other words you cant just hook a computer or some hardware upto the ecu and flash it like new models.
You need to remove the eeprom form the ecu (bet you its a Motorola chip)
(This is what I'm presuming)
Which means all you need is a chip reader/writer for the specific chip ($50 max)
The hard part is finding a definition file for the bin.
I will be able to download the contents of the chip onto my computer and view them, but without a definition file I wont have a clue whats what.
Ill be able to pull up a whole bunch of numbers, but not knowing where what is, you could be looking at a fuel map or could be the serial number for the ecu.
If you have enough patience (someone has to do this to create a definition file) is you go through trying to find everything. Bit by bit you sort stuff out, find the start and finish addresses of each table etc... Once you know where things are its easy to edit, then you just use your chip burner to write back to the eeprom and back in it goes into the ecu.
But then there are possibly checksums that need to be corrected for it to work.
Thats the chip out method, the other method is if the ECU has flash memory, then it as easy as just getting the right software, hook the comp up and away you go.
But if you say the software is 40k? I doubt it though because every other software ive seen for other makes are close to the 1000 mark, if not under.
Ill keep searching for some more info.
http://cgi.ebay.com/ebaymotors/DIGIM...ht_1268wt_1165
That should let you download the BIN file from the ecu in one way or another (not sure if this exact one supports our w208 or not)
Then you can edit the BIN file as you like, like how I said in my previous post then program straight back in.
The tricky bit is what to do with the BIN once you get it though.
Also I opened my ECU awhile ago and I think your right about the eprom Im pretty sure it was motorola.
But this also holds true for every other vehicle out there. Mercedes is no different, and tuning them is no different to any other vehicle.
When the LS1 came out it took tuners a while to crack the code, I worked at the company who designed those ECUs for a little bit. One of the guys mentioned about a password being needed and encryption, he thought it was impossible for anyone to change it. He didn't have a clue about tuners out there doing their stuff.
This will get the file to your computer, once its on our computer though we either have to have some software (still trying to tack this one down) that can help us easily edit it.
Or we could probably just use a HEX editor and hunt around trying to find the maps ourselves.
Sadly this is a serious issue with this community, one that IMO holds the entire development of these platforms back. Those that can do it keep it quiet, and there is no information shared anywhere.
(quote from the above thread)There is only one system today that is secure enough (both for user and car owner) and in fact is able to "reanimate" an ecu when needed -- OptiCan Flasher, just google it.
Its sad because everytime someone like us comes along we have to start from scratch and reinvent the wheel instead of developing the existing wheel for the better.
It definitely has kept the merc aftermarket tuner community in the dark and can be seen by the lack of knowledge.
At the current state I have given up as I do not have the time or the willingness to go through bin files and find maps and created definition files for something which is obviously done. Bit of a pity but thats the way the cookie crumbles, decided to go play with my LS2 instead and leave the merc as is.
I know a few places that sell older software, but it is kind of hit or miss on working. An Optican unit will run you 1k-1.5k and not include any software to modify the file. Good software (ECM, RACE, even Map3d to a lesser extent) is gonna run you another 2k.
This is not like the Japanese or Domestic markets when it comes to tuning. The tuning on these Euro cars is very pricey and overly complicated.
Good luck on your search though. Just remember you get what you pay for.
