99 CLK rain sensors...again!
Can anyone tell me why they are unable to reset these? They worked prior to the broken glass. They are a part of the K3 options aren't they?
Just trying to get some info for my dealer.
Thanks a million!
They are 'rain sensing wipers'.... meaning they will only wipe when the sensor senses rain..... turn it on, and pour a bucket of water on it... if it wipes, then it works. If you prefer to test it out while the car is in motion, drive around the block when it is raining.
Squirt water from the outside windshield onto the sensor, which is located in front of the rear-view mirror, a 5mm dot built into the windshield.
If the sensor works,- the more water you spray, the faster the wipe.
If the sensor does not work, it will wipe at the default rate, -- about 5 seonds for a wipe/swipe on a regular interval, - no mater how hard it rains or you squirt.
I'll try my own test at home by applying water to the windshield and see how it reacts.
Thanks again!
save gas - use the squirt/spray bottle as I suggested.
Let us know the results.
ps:
usually, when you set wipers to "intermittent", it swipes only ONCE.
If you spray to simulate rain, the swipe rate should increase according to the amount of water sprayed and sensed by the infrared dot/sensor.
