Phone
02 clk 55, 13 GL 450
yes and no.... you most likely have the old analogue system installed. Swap your PSE for a "blue label" one, add bluetooth puck and tail or use the v60 cradle with puck installed and you should be good to go as long as your car was version coded
Its an outdated part so you will have to do some digging. ebay, salvage, etc... First remove yours though as you may have the proper one. Its located behind the interior trunk cover on the drivers side below the car antenna. It's a long thin black box about 4" x12" if memory serves. You'll have to remove it from the bracket because the label is on the underside. If a light blue in color then your in business!!
