1999 clk 430 starting issues (CPS)
1999 clk 430
I am being told by a former Mercedes Benz tech that i am suppose to change out both the Crank Position Sensor and the Camshaft sensor. He is telling me that u never change out just one always the two if either goes bad. Doesn't sound right to me because the price of parts and labor goes from $145 labor and $95 for crank position sensor to $285 Labor and $165 camshaft sensor + $95 Crank postions sensor Grand Total $545. I just want to know if i only change the Crank positions sensor and my car fires up. will the camshaft sensor still need to be replaced shortly afterwards.
Any advice is greatly appreciated.
Crankshaft/Camshaft Sensor Replacement
The Crankshaft position sensor for your car is $40.00 at AutohausAZ.Very easy DIY job! MarcusF has all the info on his "Signal to Noise" site. The Camshaft position sensor is $59.00.
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
Pretty esay,I did mine this morning, same issue paid $52 at Autozone. Took me 10 minutes....Just a tip:
Use small socket set and when putting the screw back , use a piece of papertowel on the scocket. It helps the screw stay on the socket and not fall off.
2001 C320, 1997 E320, 1993 300e & 2005 F150 Supercrew
I just replaced the CPS on my CLK last weekend, it's 15 min job and I haven't had any issues. Just make sure which CPS you have (single or double clip) my 320 had the double clip. Just shine a light at the CPS and you will be able to tell by looking at the connector. I did replaced that stupid inverted torx screw with a stainless steel allen head screw. Good Luck!
