CLK headlamp washer problem!!
Old Jul 11, 2010 | 06:53 PM
carbonducati's Avatar
2001 clk 430
I have a 2001 clk430, I am having a problem with my headlamp washer not working. i have the head lights on and turn on the washer fluid but the headlamp washer doesn't work. I have tested the washer motor by giving it power and it makes the headlamp washer work and i tested the plug to the washer motor but it never gets power when i turn the washer fluid on. Any help would be great thanks.
Eric.
Old Jul 12, 2010 | 01:24 AM
VIPclk320's Avatar
CLK W208
check the relay and the fuse in the engine compartment fuse box.
Old Jul 12, 2010 | 01:56 AM
2001 clk 430
I checked the fuses listed in my manual but didn't see anything on a relay, where would the relay be located?
Old Jul 12, 2010 | 03:16 AM
VIPclk320's Avatar
CLK W208
in the back piece of the fuse box in the engine bay, you have to actually remove the screws there are about 6 of them and then remove the whole fuse box cover to get to it.
Old Jul 12, 2010 | 10:11 AM
2001 clk 430
Once i do that how do i know which relay is for the headlight washer?
