seat controls on 99 clk 430 pass /side
i cant use the adjustment controls , only the presets on the pass side seat adjustment, can i clean the contacts or do i need a new assembly...also i cant quite get the inside panel off, i must be missing a major screw or fastener....any help appreciated
Same Problem
Did you ever get an answer to your seat problem? I have a 2000 CLK430 with the same problem. I had read where someone said to reset it by running the seat all the way forward and holding for 5-10 seconds and the same going back (which I had to do with the preset) but this didn't work with mine.
i think the reason you are not getting any answers is because this has been coverd many time. Please try the search feature and I bet you find your answer.
