How remove rear bumper cover ?
Old Oct 17, 2010 | 12:33 AM
Pancho's Avatar
2000 CLK430 Cabriolet
Need to get at some rust spots ,near wheel well, to repair.
Old Oct 17, 2010 | 01:17 AM
VIPclk320's Avatar
CLK W208
i'm going to make it very short and give you the location of all the bolts.
from the outside near your tire one bolt on each side
from the inside behinde the side carpets two bolts on each side
from the inside lift the carpet on the body below the black plastic piece you will find 3 knots with washers attahed to them one is in the center below your lock latch and one on each side of it.
take all tgose off and then slide the bumper back, dont yank it up ir down just slide it back because there is a sliding bracket onn each side of the bumper and then there will be a antenna wire on the driver side that you will have to disconnect and thats it.
Old Oct 17, 2010 | 02:21 AM
Pancho's Avatar
Thanks.
I expect to get to this in about two weeks,
then will post follow up.
