Memoscan OBD11 U581 Diagnostic Tool
clk200 kompressor 2000 , 230c 1978, Ducati 900ssie, Mitsubishi Legnum VR4, Holden Barina 2006
Any one know if a Memoscan OBD11 U581 Dagnostic Tool will work on my yr 2000 clk200 kompressor? Is it worth getting one? What will it give me? Can you get the fault codes? Can it clear my engine light? I was charged more than one of these to do a code read and tell me its all ok and clear my engine light.
you may have a OBDII port under the dash on the drivers side. what I don't know is if New Zealand is compliant with OBDII requirements. and I googled it and the answer is yes so, the reader should work for you.
