Springs
Springs
I know this is asked a ton, but I'm looking to lower my 2001 430 coupe. I'm looking to have the front resting just above the tire (just about a finger width). the rear perhaps a little bit higher. Is this possible through springs? I looked at H&R as well as Eibach. Which do you recommend? Am I missing some others that I should consider?
thank you for your patience
HR the aggressive one, and u can change the pad as well bro.
get #1 pad from E320 on your car and when u go to dealer, tell em u have a 2001 e320 and u want #1 pad all around front and rear.
but its always wise TO CHANGE YOUR SHOCKS AS WELL WHEN LOWERING THE CAR DUE TO PRESSURE FROM THE CAR AND U NEED A CAMBER KIT AS WELL.
mine no pads metal to metal with HR aggressive drop and it will look like mine
but if u get #1 pad, u will have the look what u want
Thanks! I like your cars height but its a tad bit too low for me. What shocks do you recommend? those weren't something i was planning on because my current budget doesn't allow it. are there many people that don't change the shocks or is it too risky? perhaps this project will be suspended (pun intended) for a while. also with this kind of a drop will 19s still fit or will i need to drop to 18s?
sorry for all the newbie questions.
99CLK320,
You might check out Vogtland as well. Made in Germany under $240, 6 weeks delivery time. they advertise a 1.4" drop which compares to the one of the H&R kits but H&R does have a kit that drops 1.9" if you want to get that aggressive. I've read that Eibach is a progressive rate spring meaning the more they are compressed the stiffer they get so you have a smooth ride until you get agressive. and big mike is right that you will have to get adjustable camber bars for the rear and adjustable camber bushings for the front or you will wear out tires. ghostrider from this forum makes custom kits.
some peeps keeps their stock shocks but eventually they will blow and u will be paying twice for labor. its better to get it all done at the same time.
i have 19 on my car and U need to take at hte DEALER for alignment. i took it to 4 different shops and my front kept on rubbing. took it at the dealer and not a single prob bro.
u HAVE TO HAVE CAMBER KIT, OTHERWISE U WILL NEED TIRES EVERY 2 MONTHS..
CLK55 / E350 Coupe
Vogtlands are progressive they are a longer spring that supposedly thier selling point, resulting longer range of shock control...yadda yadda...they work great either way. Im have a 1.2" gap im runinng #3 or #4 pad, i'll step down to #1 pads when change my bumper.
sig pic the car is on a hill car is leaning to right.
CLK55 / E350 Coupe
Yep your right!
Product Characteristics: The spring kit is intended as an all-purpose street and track performance enhancement product. When a vehicle is equipped with Vogtland Club Spec springs there are several elements that improve the overall handling. Vogtland lowering is designed to take advantage of the existing suspension geometry and to optimize the relationship of the roll center axis relative to the center of gravity of the vehicle. The amount of lowering improves the appearance of the vehicle and provides the best compromise between the ride and performance handling characteristics.
Vogtland’s ICS (Inertia Control System) technology is utilized to provide a non-compromising performance ride. By utilizing “compound rate” springs the unsprung mass of the vehicle is controlled and the inertia of the suspension components do not exceed the springs’ capacity to control the jounce loads, hence eliminating the requirement for excessive spring rates. The initial rate is designed to provide the O.E. spring pre-load when the suspension is at full rebound. When the suspension is functioning in its normal operating range the springs “compound rate” provides a controlled performance ride but offers enough compliance to maintain occupancy comfort for street use.
The working range of the spring provides for predictable linear rate increase during the compression stroke. This eliminates unpredictable handling characteristics (i.e. corner entry understeer and corner exit oversteer) normally associated with a progressive spring. Vogtland’s optimized spring calibration also reduces the pitch of the vehicle under heavy acceleration or braking. The increased rate of the springs reduce the load transfer to the front tires during heavy braking this reduces the longitudinal pitch of the vehicle, resulting in improved overall braking efficiency.
The proportionate increase in spring rate also reduces body roll, which limits adverse suspension movement. This confines the suspension geometry to stay within parameters that enhance the tires contact patch relative to the road. The result is improved vehicle cornering and handling, because front and rear tire loading is more evenly distributed. Therefore, higher cornering limits can be achieved because the built-in understeer characteristics are reduced and provide for a more neutral yet safe handling vehicle.
These springs are manufactured utilizing Vogtland’s proprietary suspension grade “VVS” spring alloy. Vogtland’s VVS alloy is used exclusively in all our race spring applications. Vogtland’s racing springs are used by all of the most respected Winston Cup Teams such as Dale Earnhardt Inc, Hendrick Motorsports, Robert Yates Racing, etc. By using “VVS” we can reduce the spring weight up to 30% over conventional suspension spring materials. This results in reduced unsprung weight and reduces the suspension inertia allowing the suspension to react more quickly to road surface irregularities, hence providing additional traction.
Its confusing if you look at a pic of a Vogtland spring its tighter and the top and more spread out at the bottom of the coil. According to this it performs "like" a linear spring but kinda is not. Its thier own wierd monster of spring coil tech.
Purple Vogtland, red some Linear spring. Spring rate aren't as hard as H&R but are generally not as soft as Eibach springs, so your feel will be inbetween those two, pick your preference.
![](http://img20.imageshack.us/img20/6758/dsc03355mi.jpg)
