A few questions
Does the 430 have lower/different spring heights and ride stiffness?
Also, are there aftermarket springs that give the car a softer ride but slightly lower height?
so what are the main differences between eibach and h&r?
The amount of the drop and the ride quality. Eibach is known for a slighlty more comforatable ride at the expense of ride height and relative handling.
In a 430 the Eibach springs drop the front and back the same amount (1.2 inches) & the H&R's drop the front 1.4 and the back 1.3. I would go for H&R's sport springs.
I have an eibach springs in my garage but I decided to get the H&R instead. I dont like my car to sit too low.
Solihin
Have you played with the spring pads? Try to put pad #1 at the rear (I believe #1 is gives the lowest height)
edit: How many finger gaps do you have on the rear?
Solihin
