Issue on sidemirror and housing - Help needed
Old Feb 8, 2011 | 03:19 PM
bascardak's Avatar
Mercedes CLK Cabriolet 230 Kompressor W208, Mercedes G350TD W463, Mercedes B180 CDI W246
I need help on a sidemirror (drivers side), + housing.
How can I remove/assembly the mirror from the door. It´s not only the mirror it self but the whole housing.
Someone crash into the sidemirror!
I bought a new sidemirror/housing. I wanna replace it all.
So I need help to my issue.........
Best regards from EUROPE!
Bascardak
Old Feb 8, 2011 | 04:51 PM
VIPclk320's Avatar
CLK W208
Bascardak
Remove the twitter cover (inside the car), you will see 3 gold color screws, loosen those up and the whole mirror assembly come off, the screws are in a triangle formation, the two that are on top of each other can be easily removed from behinde the twitter cover but the lower front one cant, so in order to remove that open your door all the way and you will see a plastic cover on the leather piece of the door. pop that piece out gently with a flat head and youse a long screw driver to take that last screw out, just be sure to use a magnetic screw driver because if one of the screws falls then you will have to remove the whole door panel.
in order to disconnect the wiring and the internal, you will have to take off the mirror lens which has a spring loaded clip on the top middle which you will nees a clip remover to push it back and then pull it up and the lens will pop out and you will see the motor sitting on the mirror frame by 3 screws (allen screws) from there its very straight forward, i'm sure you can figure it out by just looking at it.
Old Feb 9, 2011 | 09:58 AM
bascardak's Avatar
Many many thank´s.....!
I will try that.
Best regards
Bascardak
