Aftermarket Radio Install Question
Was following all of the threads today (thanks to all especially Marcus) and trying to install my new Pioneer MVH-P8200BT when it wouldn't power on. Long story short (about 2 hours of troubleshooting) the wiring harness in my 01 CLK430 Cab. does not have a pin in the 3rd position in the bottom row, which is where the red wire is). The pin above the ground shows a constant 12.5 volts, but there is no other live pin that I can hook up the switched to...so here is my question - Crutchfield said it should be OK to hook it up to the cig. lighter wire.
Does this sound OK? If so, then any ideas on how to get the ash tray assembly out so I can look at the wire?
Also, I will be hooking up an XM (Pioneer GEX-920XM) as well and I wanted to use the lighter wire for that hookup. Would it be OK to hook up 2 power wires to the lighter?
What's everyone think - please let me know for this is a summer car with 31k on the spedo and I wanted to have this done within the next month so I can break it out for Spring. Thanks!
Once you have you stock headunit out the cig +/- wires are in plain view.
not sure of the amperage/watts for cig but your two componets (XM and HU) im sure won't be much of a draw of power, i would think would be just fine. If its too much you'll probably just pop a fuse
If so look for another switched power source...theres plenty of em all over the console.
