99 CLK430 Misfires, and poor acceleration above 1/2 throttle or 3000 rpm.
Old Mar 2, 2011 | 01:28 AM
senorking's Avatar
1999 CLK430
I have a 99 CLK430, about 120,000 miles on it. I have been having trouble with hard starting, misfires, and poor or no acceleration. I have run a couple of fuel system cleaners through it including BG44K with no luck. It has a brand new Bosch Fuel Pump, new fuel filter, and clean (lightly oiled) K&N's. I have also checked the filter housing and ducts for obstructions. I have a brand new BOSCH Air Mass Sensor from AZPartshauz that I have tried swapping out with the original, but it has no effect. Today it would barely run, and finally triggered the CEL. I looked under the hood and noticed the vacuum line, connecting what I believe are called "EGR Shut Off Valves" on the front of the manifold, was rotted away so I replaced it. Started it up and it ran better but not great. Next I hooked up OBDWIZ and looked at the trouble codes and PID readings.
P0300, P0301, P0302, P0303, P0305
It's also showing for O2 Sensor 1, Bank 1: "Minimum Sensor voltage for test cycle: fail" and also "Maximum Sensor Voltage for test cycle: fail" I was also concerned about the timing advance reading, as it is reading negative "-" before the value, every other vehicle I've hooked this up to does not read negative.
I used OBDWIZ to clear the codes, started it up, and it was running much better. But still poor, unpredictable acceleration especially above 1/2 throttle and above 3000-3500 rpm. I recorded the logs for about 45 minutes at idle, low speed, and highway speed, and attached them to this thread. I also included the overall stats for all the PID's. I got back to the house and idled in the driveway for a few minutes while I looked over the logs. Then I decided I would drive it again. It started almost normal, and within a 1/4 mile the CEL came back on and it began stumbling hard. I cleared the codes again and it returned to the same condition of running better, but stumbling above 1/2 throttle, or above 3000-3500 rpm.
Sorry for the lengthy description, but I figured it's best to state everything I know about the problem. I would greatly appreciate any help that you all can offer, I can't figure this one out.
Attached Thumbnails 99 CLK430 Misfires, and poor acceleration above 1/2 throttle or 3000 rpm.-plot-1.jpg   99 CLK430 Misfires, and poor acceleration above 1/2 throttle or 3000 rpm.-plot-2.jpg   99 CLK430 Misfires, and poor acceleration above 1/2 throttle or 3000 rpm.-plot-3.jpg   99 CLK430 Misfires, and poor acceleration above 1/2 throttle or 3000 rpm.-plot-4.jpg   99 CLK430 Misfires, and poor acceleration above 1/2 throttle or 3000 rpm.-plot-5.jpg
99 CLK430 Misfires, and poor acceleration above 1/2 throttle or 3000 rpm.-plot-6.jpg
Old Mar 2, 2011 | 01:37 AM
senorking's Avatar
1999 CLK430
Here are the other screenshots...
One more thing, it does not seem to kick down reliably, even when going to the manual kickdown at full throttle. Yesterday I was thinking about the TPS, until I saw the O2 readings today. Also, I have pulled a few spark plugs and looked at them. Also, I pulled the plugs on cylinders 1 & 5, they aren't great so I ordered a new set, but they don't look bad enough to be causing these problems by themselves.
Attached Thumbnails 99 CLK430 Misfires, and poor acceleration above 1/2 throttle or 3000 rpm.-stats.jpg   99 CLK430 Misfires, and poor acceleration above 1/2 throttle or 3000 rpm.-o2-sensors.jpg
Old Mar 24, 2011 | 10:18 PM
senorking's Avatar
1999 CLK430
Problem Solved, I wrote a novel about the solutions here:
https://mbworld.org/forums/clk-class...ml#post4589588
Old Mar 24, 2011 | 11:56 PM
jbenz2001's Avatar
2001 clk 320
Great write up and pics.will have to do a nice check up on my car.I know at times when I push the car wot my check engine pops on and gives me the code for the egr valve.ima have to check the hose for any cracks cuz I surely don't need any sand in my manifold.this forum is great thanks to guys like u that inform us of your problems and showing us how to solve them.I've saved tons of money by (switching to geico) lol.no really I've saved a lot of money by joining this forum.thanks senorking and to all that help us out.
Old Mar 25, 2011 | 12:18 AM
jbenz99's Avatar
Sold 2003 CLK 500,2003 SL 500,2006 Acura MDX,1998 BMW M3 convertible
lmao !!! jbenz2001
Attached Thumbnails 99 CLK430 Misfires, and poor acceleration above 1/2 throttle or 3000 rpm.-geico450_35768c.jpg   99 CLK430 Misfires, and poor acceleration above 1/2 throttle or 3000 rpm.-geicocavemen.jpg
Old Jul 30, 2021 | 11:54 PM
BooGator's Avatar
'99 CLK430, '01 C240
Coil packs
